Ga door naar hoofdinhoud
Dell XPS 9720 Battery Replacement
Wat je nodig hebt
  1. Dell XPS 9720 Battery Replacement, Remove back cover: stap 1, afbeelding 1 van 1
    • Remove 8 T5 screws. Use an opening tool to pop open the plastic tabs that hold the aluminum and plastic halves of the shell together. Begin by inserting the tool at any point, then sliding it around the perimeter of the device to release all of the tabs. There are no tabs along the hinge side of the device.
  2. Dell XPS 9720 Battery Replacement, Unplug the battery: stap 2, afbeelding 1 van 2 Dell XPS 9720 Battery Replacement, Unplug the battery: stap 2, afbeelding 2 van 2
    • Place a finger through the plastic loop attached to the battery plug, and pull firmly away from the motherboard.
  3. Dell XPS 9720 Battery Replacement, Remove battery screws: stap 3, afbeelding 1 van 2 Dell XPS 9720 Battery Replacement, Remove battery screws: stap 3, afbeelding 2 van 2
    • Unscrew the 7 PH1 screws retaining the battery.
    • The battery can now be lifted from the chassis.
    • Reverse the steps to install the new battery.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sebastien Bolle
350 Reputatie
3 handleidingen geschreven
Één opmerking
Is there anything to do on the software side to the battery replacement? Or is it plug and play?
Steven Savoie - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 65
Altijd: 1,287
