Ga door naar hoofdinhoud
Dell XPS 7590 SSD Replacement
Wat je nodig hebt
  1. Dell XPS 7590 SSD Replacement, Flip laptop around: stap 1, afbeelding 1 van 1
    • Flip your device the other way around
    • Don't be confused that this device is black, its a skin
  2. Dell XPS 7590 SSD Replacement, Remove 10 Torx T5: stap 2, afbeelding 1 van 3 Dell XPS 7590 SSD Replacement, Remove 10 Torx T5: stap 2, afbeelding 2 van 3 Dell XPS 7590 SSD Replacement, Remove 10 Torx T5: stap 2, afbeelding 3 van 3
    • Grab your T5 Torx and identify the 10 torx screws
    • Make sure that this is a T5, to not strip the screws. They can be very difficult to remove
    • Careful there are more screws, do not try to open yet!
  3. Dell XPS 7590 SSD Replacement, Remove Flap Screws: stap 3, afbeelding 1 van 1
    • Open the flap on the back of the laptop
    • There are two screws that need to be removed, please use a Philips 0 screwdriver
  4. Dell XPS 7590 SSD Replacement, Remove Backplate: stap 4, afbeelding 1 van 1
    • The backplate might not be easy to open
    • You can use a soft prytool to open the laptop easier
    • Don't insert the tool too deep or you might break the mainboard
    • Now, you should be able to remove the backplate
  5. Dell XPS 7590 SSD Replacement, Unplug Battery: stap 5, afbeelding 1 van 3 Dell XPS 7590 SSD Replacement, Unplug Battery: stap 5, afbeelding 2 van 3 Dell XPS 7590 SSD Replacement, Unplug Battery: stap 5, afbeelding 3 van 3
    • Locate the battery connection to the mainboard
    • Unplug the battery before doing anything else
    • You can use a pry tool to make this easier
  6. Dell XPS 7590 SSD Replacement, Locate and remove SDD: stap 6, afbeelding 1 van 3 Dell XPS 7590 SSD Replacement, Locate and remove SDD: stap 6, afbeelding 2 van 3 Dell XPS 7590 SSD Replacement, Locate and remove SDD: stap 6, afbeelding 3 van 3
    • Locate the SDD on the mainboard
    • Use a Philips 0 to remove the screw of the SDD
    • Slide the SSD out of its socket.
    • Try not to lift the SSD any more than necessary
    • During reassembly, make sure the slot in the SSD lines up with the slot in its socket. Do not touch the gold-colored contacts with your fingers.
    • Reconnect the battery and reassemble
Conclusie
4 andere personen hebben deze handleiding voltooid.
Max Lembke
951 Reputatie
3 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 51
Altijd: 3,904
