Ga door naar hoofdinhoud
Dell XPS 720 H2C Card Fan Replacement
  1. Dell XPS 720 H2C Card Fan Replacement, Removing Dell XPS 720 H2C Cover Panel: stap 1, afbeelding 1 van 2 Dell XPS 720 H2C Card Fan Replacement, Removing Dell XPS 720 H2C Cover Panel: stap 1, afbeelding 2 van 2
    • Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
  2. Dell XPS 720 H2C Card Fan Replacement, Card Fan: stap 2, afbeelding 1 van 2 Dell XPS 720 H2C Card Fan Replacement, Card Fan: stap 2, afbeelding 2 van 2
    • The card fan is located at the bottom left corner of the computer.
    • Remove the cable connecting the fan to the motherboard.
    • You will have to push a tiny lever on top of the connector and pull the cable to the left at the same time to remove the cable from the motherboard.
  3. Dell XPS 720 H2C Card Fan Replacement: stap 3, afbeelding 1 van 2 Dell XPS 720 H2C Card Fan Replacement: stap 3, afbeelding 2 van 2
    • Disconnect the fan from the cage housing by pressing down on the release triggers and pushing them to the right.
  4. Dell XPS 720 H2C Card Fan Replacement: stap 4, afbeelding 1 van 2 Dell XPS 720 H2C Card Fan Replacement: stap 4, afbeelding 2 van 2
    • Slide each corner of the fan cage off of the rubber grommets attached to the fan.
    • The rubber grommets may be difficult to remove. You have to squeeze the base of the grommet and pull the cage apart at the same time. The grommets should be pulled apart one at a time.
Conclusie
3 andere personen hebben deze handleiding voltooid.
G B
67 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 10
Altijd: 1,963
