Ga door naar hoofdinhoud
Inleiding
This guide shows how to detach the wireless WLAN card wires. This is not a replacement guide for the wires or the card.
  1. Turn the device on its screen.
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Gently flip out support feet located near the bottom of device.
    • Gently flip out support feet located near the bottom of device.
  3. Gently lift the back cover off the device. The back cover should come off easily.
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
    • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
  5. Laptop batterijen
    An easy fix for a big power boost.
    Nu winkelen
    Laptop batterijen
    Nu winkelen
  6. Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle. Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
    • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
  7. Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver. Remove the internal cover.
    • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
    • Remove the internal cover.
  8. Disconnect the black camera cable and pull it back to prevent future hassle. Disconnect the black camera cable and pull it back to prevent future hassle.
    • Disconnect the black camera cable and pull it back to prevent future hassle.
  9. Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable. Disconnect the silver and blue touch control board cable.
    • Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable.
    • Disconnect the silver and blue touch control board cable.
  10. Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver. Remove the touch control board.
    • Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver.
    • Remove the touch control board.
  11. Use the plastic opening tool's angled edge to remove the black and white wires connected to the wireless WLAN card.
    • Use the plastic opening tool's angled edge to remove the black and white wires connected to the wireless WLAN card.
  12. Pull back the cables. Pull back the cables.
    • Pull back the cables.
Conclusie
Austin Weir
1.172 Reputatie
8 handleidingen geschreven
Cal Poly, Team 6-29, Amido Winter 2015 Lid van Cal Poly, Team 6-29, Amido Winter 2015
CPSU-AMIDO-W15S6G29
4 Leden
16 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 35
