Ga door naar hoofdinhoud
Dell XPS 18 Left and Right Speakers Replacement
Wat je nodig hebt
  1. Dell XPS 18 Left and Right Speakers Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Left and Right Speakers Replacement: stap 2, afbeelding 1 van 1
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Left and Right Speakers Replacement: stap 3, afbeelding 1 van 1
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Left and Right Speakers Replacement, Left and Right Speakers: stap 4, afbeelding 1 van 2 Dell XPS 18 Left and Right Speakers Replacement, Left and Right Speakers: stap 4, afbeelding 2 van 2
    • Use the plastic opening tool's angled edge to lift the clasp securing the copper colored volume control cable.
    • Disconnect the volume control cable and pull it back.
  5. Dell XPS 18 Left and Right Speakers Replacement: stap 5, afbeelding 1 van 1
    • Firmly pull the blue speaker cable loose.
  6. Dell XPS 18 Left and Right Speakers Replacement: stap 6, afbeelding 1 van 1
    • Remove the two black 4mm screws with a Phillips 00 screwdriver.
  7. Dell XPS 18 Left and Right Speakers Replacement: stap 7, afbeelding 1 van 1
    • Carefully remove the speaker.
    • To remove the right speaker, follow these same steps.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Austin Weir
1.287 Reputatie
8 handleidingen geschreven
Cal Poly, Team 6-29, Amido Winter 2015 Lid van Cal Poly, Team 6-29, Amido Winter 2015
CPSU-AMIDO-W15S6G29
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 1,296
