Ga door naar hoofdinhoud
Inleiding
This guide is used as a prerequisite for replacing internal parts in the Dell XPS 18
  1. Turn the device on its screen.
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Gently flip out support feet located near the bottom of device.
    • Gently flip out support feet located near the bottom of device.
  3. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Nu winkelen
    iPhone X Fix Kits
    Nu winkelen
  4. Gently lift the back cover off the device. The back cover should come off easily.
    • Gently lift the back cover off the device. The back cover should come off easily.
  5. Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
    • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
  6. Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle. Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
    • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
  7. Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver. Remove the internal cover.
    • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
    • Remove the internal cover.
Conclusie
Austin Weir
1.172 Reputatie
8 handleidingen geschreven
Cal Poly, Team 6-29, Amido Winter 2015 Lid van Cal Poly, Team 6-29, Amido Winter 2015
CPSU-AMIDO-W15S6G29
4 Leden
16 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 31
