Ga door naar hoofdinhoud
Dell XPS 18 Battery Replacement
Wat je nodig hebt
  1. Dell XPS 18 Battery Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Battery Replacement: stap 2, afbeelding 1 van 1
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Battery Replacement: stap 3, afbeelding 1 van 1
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Battery Replacement, Internal Cover: stap 4, afbeelding 1 van 1
    • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
  5. Dell XPS 18 Battery Replacement: stap 5, afbeelding 1 van 2 Dell XPS 18 Battery Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
  6. Dell XPS 18 Battery Replacement: stap 6, afbeelding 1 van 2 Dell XPS 18 Battery Replacement: stap 6, afbeelding 2 van 2
    • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
    • Remove the internal cover.
  7. Dell XPS 18 Battery Replacement, Touch Control Board: stap 7, afbeelding 1 van 2 Dell XPS 18 Battery Replacement, Touch Control Board: stap 7, afbeelding 2 van 2
    • Disconnect the black camera cable and pull it back to prevent future hassle.
  8. Dell XPS 18 Battery Replacement: stap 8, afbeelding 1 van 2 Dell XPS 18 Battery Replacement: stap 8, afbeelding 2 van 2
    • Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable.
    • Disconnect the silver and blue touch control board cable.
  9. Dell XPS 18 Battery Replacement: stap 9, afbeelding 1 van 2 Dell XPS 18 Battery Replacement: stap 9, afbeelding 2 van 2
    • Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver.
    • Remove the touch control board.
  10. Dell XPS 18 Battery Replacement, Wireless WLAN Card Wires: stap 10, afbeelding 1 van 1
    • Use the plastic opening tool's angled edge to remove the black and white wires connected to the wireless WLAN card.
  11. Dell XPS 18 Battery Replacement: stap 11, afbeelding 1 van 2 Dell XPS 18 Battery Replacement: stap 11, afbeelding 2 van 2
    • Pull back the cables.
  12. Dell XPS 18 Battery Replacement, Battery: stap 12, afbeelding 1 van 1
    • Use the plastic opening tool's angled edge to pry the black battery cable loose.
  13. Dell XPS 18 Battery Replacement: stap 13, afbeelding 1 van 1
    • Use the plastic opening tool's angled edge to remove the red and black CMOS battery cable.
  14. Dell XPS 18 Battery Replacement: stap 14, afbeelding 1 van 2 Dell XPS 18 Battery Replacement: stap 14, afbeelding 2 van 2
    • Use the plastic opening tool's angled edge to lift the clasp securing the silver circuit board cable.
    • Pull back the circuit board cable to prevent future hassle.
  15. Dell XPS 18 Battery Replacement: stap 15, afbeelding 1 van 1
    • Use the opening tool's angled edge to remove the CMOS battery.
    • The CMOS battery is adhered with strong adhesive; you may need to use extra force when removing.
  16. Dell XPS 18 Battery Replacement: stap 16, afbeelding 1 van 1
    • Remove the eleven black 4mm screws holding the battery in place with a Phillips 00 screwdriver.
  17. Dell XPS 18 Battery Replacement: stap 17, afbeelding 1 van 1
    • Remove the battery.
Conclusie
13 andere personen hebben deze handleiding voltooid.
Austin Weir
1.287 Reputatie
8 handleidingen geschreven
Cal Poly, Team 6-29, Amido Winter 2015 Lid van Cal Poly, Team 6-29, Amido Winter 2015
CPSU-AMIDO-W15S6G29
4 Leden
16 handleidingen geschreven
9 opmerkingen
needs the help to repair the Dell XPS18
anrew waleta - Antwoord
This is an excellent doc! Pictures are really clear and accurate, steps are concise and best of all they are correct. I was able to solve my issue the first go round with these instructions. Kudos to the author and thanks a million for the assistance!
stacysaw - Antwoord
It all worked good. Thanks.
Kenneth Macdonald - Antwoord
Excellent!
What is the battery type and where to buy, thanks
Mohammad - Antwoord
My unit is missing the right foot stand. Is there anywhere else I can find the model number. Need to purchase a new power supply?
Also might need to replace the touchscreen its cracked. Have to power her up first to find out. Do you have a video for touchscreen replacement?
Frank Schofield - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 45
Altijd: 15,889
