Ga door naar hoofdinhoud
Dell XPS 17 L702X Hard Drive Replacement
Wat je nodig hebt
  1. Dell XPS 17 L702X Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip over the laptop so that the bottom battery compartment faces upwards.
  2. Dell XPS 17 L702X Hard Drive Replacement: stap 2, afbeelding 1 van 2 Dell XPS 17 L702X Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Slide the tab below the battery to the left and hold the tab in place.
  3. Dell XPS 17 L702X Hard Drive Replacement: stap 3, afbeelding 1 van 2 Dell XPS 17 L702X Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • While holding the tab, lift the battery out of its compartment.
    • Release the tab after removing the battery.
  4. Dell XPS 17 L702X Hard Drive Replacement, Hard Drive: stap 4, afbeelding 1 van 1
    • Loosen the module cover screw with a Phillips screwdriver.
    • The screw is attached to the cover; do not force it out.
  5. Dell XPS 17 L702X Hard Drive Replacement: stap 5, afbeelding 1 van 3 Dell XPS 17 L702X Hard Drive Replacement: stap 5, afbeelding 2 van 3 Dell XPS 17 L702X Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards.
  6. Dell XPS 17 L702X Hard Drive Replacement: stap 6, afbeelding 1 van 2 Dell XPS 17 L702X Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • Remove the four 4mm Phillips screws fastening the first hard drive.
  7. Dell XPS 17 L702X Hard Drive Replacement: stap 7, afbeelding 1 van 3 Dell XPS 17 L702X Hard Drive Replacement: stap 7, afbeelding 2 van 3 Dell XPS 17 L702X Hard Drive Replacement: stap 7, afbeelding 3 van 3
    • Slide the hard drive with your hand towards the hole where the back panel assembly screw was located (in step 5) to disconnect it.
    • Lift the hard drive up to remove it from the case.
  8. Dell XPS 17 L702X Hard Drive Replacement: stap 8, afbeelding 1 van 1
    • Remove the four 4mm Phillips screws on the second hard drive.
  9. Dell XPS 17 L702X Hard Drive Replacement: stap 9, afbeelding 1 van 2 Dell XPS 17 L702X Hard Drive Replacement: stap 9, afbeelding 2 van 2
    • Slide the hard drive towards the edge nearest you to disconnect it.
  10. Dell XPS 17 L702X Hard Drive Replacement: stap 10, afbeelding 1 van 3 Dell XPS 17 L702X Hard Drive Replacement: stap 10, afbeelding 2 van 3 Dell XPS 17 L702X Hard Drive Replacement: stap 10, afbeelding 3 van 3
    • Using the tab that says "THIS SIDE UP," pull away from the laptop to remove the hard drive.
  11. Dell XPS 17 L702X Hard Drive Replacement: stap 11, afbeelding 1 van 2 Dell XPS 17 L702X Hard Drive Replacement: stap 11, afbeelding 2 van 2
    • Repeat this step for each hard drive.
    • Unscrew the two 4mm screws from each side of the hard drive casing with a Phillips screwdriver.
  12. Dell XPS 17 L702X Hard Drive Replacement: stap 12, afbeelding 1 van 1
    • Remove the hard drive casing.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Shin Sul
544 Reputatie
3 handleidingen geschreven
CSU Fullerton, Team 2-6, Bruce Fall 2015 Lid van CSU Fullerton, Team 2-6, Bruce Fall 2015
CSUF-BRUCE-F15S2G6
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 4,341
