Ga door naar hoofdinhoud
Dell XPS 15-L502X RAM Replacement
Wat je nodig hebt
  1. Dell XPS 15-L502X RAM Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the black battery bar from the computer before continuing any further operations.
    • Unscrew the three 5mm Phillps #2 screws on the left side of the back panel.
  2. Dell XPS 15-L502X RAM Replacement: stap 2, afbeelding 1 van 1
    • Lift up the left side of the panel.
    • There are three tabs holding in the right side of the panel. Pull the panel up and away from these tabs to remove it.
  3. Dell XPS 15-L502X RAM Replacement, RAM: stap 3, afbeelding 1 van 1
    • Locate both of the RAM slots right behind the back panel.
  4. Dell XPS 15-L502X RAM Replacement: stap 4, afbeelding 1 van 1
    • Use a black spudger to press the clips holding the RAM outward. You should hear a "click" sound.
    • Once both clips have been released, the RAM will be released at a 45 degree angle.
  5. Dell XPS 15-L502X RAM Replacement: stap 5, afbeelding 1 van 1
    • Carefully grab the RAM with both hands and pull outward.
    • Repeat steps 4 & 5 to remove the second RAM.
    • Both RAMs should come out without much force. Do not attempt to pull the RAM out with force as this could damage the fixture holding the RAM.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Vishal
778 Reputatie
6 handleidingen geschreven
IUPUI, Team 2-3, Baechle Fall 2015 Lid van IUPUI, Team 2-3, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G3
3 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 2,331
