Inleiding
Use this guide in order to replace or upgrade your solid state drive (SSD) on the Dell XPS 15 9575.
The solid state drive is responsible for the long term or non-volatile storage of data on the device. If your computer comes up with a data corruption error, it’s most likely the cause of a malfunctioning solid state drive. The SSD also contains the operating system for the device, so if your computer has difficulties starting up this may also be a sign of a faulty SSD.
Check out the Dell XPS 15 9575 Troubleshooting Page for more information on problems you might experience with your SSD.
Wat je nodig hebt
Use your T5 Torx driver to remove all eight 3.2mm hex screws holding down the back panel.
Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
Use the Phillips #0 Screwdriver to remove a single 3.2mm screw from the SSD Drive.
Do you have a picture showing the tail end (what’s that) flipped up?
Carefully slide the SSD from its port, removing it from the device.
2 opmerkingen
After replacing the SSD 256GB to 1TB the Power Led started blinking yellow 4 times, white one time when powered by the AC adapter. The internal battery seemes to be disabled somehow. Any suggestions whats missing? Open cover detection maybe? There are no error messages from the bios, windows is running without problems.
This seemed to be caused by accidentially switching of the little white switch right beside the ssd when placing the ssd into the connector. After switching it on again, it worked as before, no led blinking and running from battery again.
I found it quite tough to make the initial pick insertion. The easiest point for me was on the rear edge of the laptop just to the outside of the hinge.
The screws were all same size so no need to remember which came from where.
Mr Mac - Antwoord
