Inleiding
This guide shows how to remove and replace the I/O board of your Dell XPS 15 9575. Before you begin this repair, turn off your laptop and unplug it from the charger.
Wat je nodig hebt
Use your T5 Torx driver to remove all eight 3.2 mm screws holding down the back panel.
Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
Use the Phillips #0 screwdriver to remove all four silver 3.2 mm screws fastening the interconnect cable.
Use the Phillips #0 screwdriver to remove all eight 6.4 mm screws from the battery.
Use the Phillips 0 Screwdriver to carefully extract each of the four 3.2 mm screws.
Use a spudger or a clean fingernail to flip up the locking flap of the ZIF connector.
Use tweezers or your fingers to gently pull the orange cable out of its socket on the I/O board.
