Ga door naar hoofdinhoud
Dell XPS 15 9570 Keyboard Replacement
Wat je nodig hebt
  1. Dell XPS 15 9570 Keyboard Replacement, Base Cover: stap 1, afbeelding 1 van 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Keyboard Replacement: stap 2, afbeelding 1 van 3 Dell XPS 15 9570 Keyboard Replacement: stap 2, afbeelding 2 van 3 Dell XPS 15 9570 Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Keyboard Replacement: stap 3, afbeelding 1 van 2 Dell XPS 15 9570 Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Keyboard Replacement, Battery: stap 5, afbeelding 1 van 1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Keyboard Replacement, Heat Sink: stap 8, afbeelding 1 van 2 Dell XPS 15 9570 Keyboard Replacement, Heat Sink: stap 8, afbeelding 2 van 2
    • Use the Phillips #00 to remove the three (without graphics card) or four (with graphics card) 3 mm screws that connect the heat sink to the system board.
  9. Dell XPS 15 9570 Keyboard Replacement: stap 9, afbeelding 1 van 1
    • Lift the heat sink from the device. The thermal paste may have dried and make this handling more complicated, be careful.
  10. Dell XPS 15 9570 Keyboard Replacement, Fan: stap 10, afbeelding 1 van 2 Dell XPS 15 9570 Keyboard Replacement, Fan: stap 10, afbeelding 2 van 2
    • Use the Phillips #00 screwdriver to remove the two 4 mm screws securing the grey display cable bracket.
  11. Dell XPS 15 9570 Keyboard Replacement: stap 11, afbeelding 1 van 1
    • Using the Phillips #00 screwdriver, remove the 4 mm screw at the back right corner of the fan.
  12. Dell XPS 15 9570 Keyboard Replacement: stap 12, afbeelding 1 van 2 Dell XPS 15 9570 Keyboard Replacement: stap 12, afbeelding 2 van 2
    • Disconnect the fan cable on the left of the fan and on the right side from the RAM, using the opening tool.
  13. Dell XPS 15 9570 Keyboard Replacement: stap 13, afbeelding 1 van 1
    • Lift the right fan off of the device.
    • Repeat steps 8-11 to remove the left fan from the system board.
    • The left fan is fixed with two 4 mm screws. Make sure you have removed them if the fan does not come off easily.
  14. Dell XPS 15 9570 Keyboard Replacement, RAM: stap 14, afbeelding 1 van 2 Dell XPS 15 9570 Keyboard Replacement, RAM: stap 14, afbeelding 2 van 2
    • Use your fingers to pinch down the metal tabs holding the RAM in place. Do this for each tab.
  15. Dell XPS 15 9570 Keyboard Replacement: stap 15, afbeelding 1 van 1
    • Use your hands to carefully lift the RAM up and away from the tabs to safely take it out.
  16. Dell XPS 15 9570 Keyboard Replacement, SSD: stap 16, afbeelding 1 van 2 Dell XPS 15 9570 Keyboard Replacement, SSD: stap 16, afbeelding 2 van 2
    • Use the Phillips #00 screwdriver to remove the 5.5 mm screw next to the SSD.
  17. Dell XPS 15 9570 Keyboard Replacement: stap 17, afbeelding 1 van 2 Dell XPS 15 9570 Keyboard Replacement: stap 17, afbeelding 2 van 2
    • Using your hands, hold the SSD and slightly pull to the left.
  18. Dell XPS 15 9570 Keyboard Replacement, Wireless Card: stap 18, afbeelding 1 van 2 Dell XPS 15 9570 Keyboard Replacement, Wireless Card: stap 18, afbeelding 2 van 2
    • Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
  19. Dell XPS 15 9570 Keyboard Replacement: stap 19, afbeelding 1 van 1
    • Lift the wireless card bracket off of the wireless card.
  20. Dell XPS 15 9570 Keyboard Replacement: stap 20, afbeelding 1 van 2 Dell XPS 15 9570 Keyboard Replacement: stap 20, afbeelding 2 van 2
    • Using a spudger, disconnect the coaxial antenna cables from the Wi-Fi card by popping them gently off.
  21. Dell XPS 15 9570 Keyboard Replacement: stap 21, afbeelding 1 van 1
    • Carefully remove the wireless card.
  22. Dell XPS 15 9570 Keyboard Replacement, Keyboard: stap 22, afbeelding 1 van 2 Dell XPS 15 9570 Keyboard Replacement, Keyboard: stap 22, afbeelding 2 van 2
    • Disconnect the two motherboard cables using the opening tool.
  23. Dell XPS 15 9570 Keyboard Replacement: stap 23, afbeelding 1 van 3 Dell XPS 15 9570 Keyboard Replacement: stap 23, afbeelding 2 van 3 Dell XPS 15 9570 Keyboard Replacement: stap 23, afbeelding 3 van 3
    • Using a Phillips #0 screwdriver, remove the four 4mm screws securing the hard drive cover.
  24. Dell XPS 15 9570 Keyboard Replacement: stap 24, afbeelding 1 van 3 Dell XPS 15 9570 Keyboard Replacement: stap 24, afbeelding 2 van 3 Dell XPS 15 9570 Keyboard Replacement: stap 24, afbeelding 3 van 3
    • Disconnect the two motherboard cables located on the right of the motherboard using the opening tool.
  25. Dell XPS 15 9570 Keyboard Replacement: stap 25, afbeelding 1 van 2 Dell XPS 15 9570 Keyboard Replacement: stap 25, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver, unscrew the 4 remaining 4mm screws holding the motherboard in place.
    • Remove the motherboard.
  26. Dell XPS 15 9570 Keyboard Replacement: stap 26, afbeelding 1 van 2 Dell XPS 15 9570 Keyboard Replacement: stap 26, afbeelding 2 van 2
    • Disconnect the keyboard cables, labeled BL and KB, using the opening tool.
  27. Dell XPS 15 9570 Keyboard Replacement: stap 27, afbeelding 1 van 3 Dell XPS 15 9570 Keyboard Replacement: stap 27, afbeelding 2 van 3 Dell XPS 15 9570 Keyboard Replacement: stap 27, afbeelding 3 van 3
    • Unscrew the 1.9mm screws using a Phillips #00 screwdriver.
    • Flip the cutouts on the keyboard to reveal and unscrew remaining 1.9mm screws underneath.
    • Remove the keyboard.
Conclusie
Sophie
301 Reputatie
2 handleidingen geschreven
IUPUI, Team 3-1, Harley Fall 2023 Lid van IUPUI, Team 3-1, Harley Fall 2023
IUPUI-HARLEY-F23S3G1
4 Leden
3 handleidingen geschreven
Één opmerking
Thanks alot.
Motherboard: 2 more cables to disconnect.
Keyboard backside some more screws to remove.
Mister Iks - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 36
Afgelopen 30 dagen: 107
Altijd: 1,410
