Ga door naar hoofdinhoud
Dell XPS 15 9570 Heat Sink Replacement
Wat je nodig hebt
  1. Dell XPS 15 9570 Heat Sink Replacement, Base Cover: stap 1, afbeelding 1 van 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Heat Sink Replacement: stap 2, afbeelding 1 van 3 Dell XPS 15 9570 Heat Sink Replacement: stap 2, afbeelding 2 van 3 Dell XPS 15 9570 Heat Sink Replacement: stap 2, afbeelding 3 van 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Heat Sink Replacement: stap 3, afbeelding 1 van 2 Dell XPS 15 9570 Heat Sink Replacement: stap 3, afbeelding 2 van 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Heat Sink Replacement: stap 4, afbeelding 1 van 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Heat Sink Replacement, Battery: stap 5, afbeelding 1 van 1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Heat Sink Replacement: stap 6, afbeelding 1 van 1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Heat Sink Replacement: stap 7, afbeelding 1 van 1
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Heat Sink Replacement, Heat Sink: stap 8, afbeelding 1 van 2 Dell XPS 15 9570 Heat Sink Replacement, Heat Sink: stap 8, afbeelding 2 van 2
    • Use the Phillips #00 to remove the three (without graphics card) or four (with graphics card) 3 mm screws that connect the heat sink to the system board.
  9. Dell XPS 15 9570 Heat Sink Replacement: stap 9, afbeelding 1 van 1
    • Lift the heat sink from the device. The thermal paste may have dried and make this handling more complicated, be careful.
Conclusie
Margaret Combs
516 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 43
Altijd: 2,778
