Inleiding
How to replace a scratched, cracked, or unresponsive trackpad on a Dell XPS 15 9560 laptop.
Before using this guide, be sure to check that there is nothing else that could be causing or contributing to issues with the trackpad. One possible issue could be with your trackpad drivers. Here is a video by MDTechVideos that explains how to fix this issue. Another possible issue is that your trackpad has dust or debris on it. Fix this by spraying isopropyl alcohol on a microfiber cloth, then apply medium pressure the the surface of the trackpad and wipe the cloth in small circles on and around the trackpad.
Wat je nodig hebt
Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
Using a Phillips #0 screwdriver, remove four 4.0 mm screws of the hard drive bracket.
Unplug the hard drive cable.
