Ga door naar hoofdinhoud
Dell XPS 15 9560 Motherboard Replacement
Wat je nodig hebt
  1. Dell XPS 15 9560 Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  2. Dell XPS 15 9560 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips #2 screwdriver, remove two 5.0 mm screws underneath the XPS badge door.
  3. Dell XPS 15 9560 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  4. Dell XPS 15 9560 Motherboard Replacement, Battery: stap 4, afbeelding 1 van 1
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
  5. Dell XPS 15 9560 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Unplug the battery cable.
  6. Dell XPS 15 9560 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the battery.
  7. Dell XPS 15 9560 Motherboard Replacement, Hard Drive: stap 7, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove four 4.0 mm screws of the hard drive bracket.
    • Unplug the hard drive cable.
  8. Dell XPS 15 9560 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the hard drive bracket. Then, unplug and remove the hard drive.
  9. Dell XPS 15 9560 Motherboard Replacement, Solid State Drive (SSD): stap 9, afbeelding 1 van 1
    • Using a Phillips #2 screwdriver, remove a single 3.0 mm screw from the SSD bracket.
  10. Dell XPS 15 9560 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Using the same Phillips #2 screwdriver, unscrew and remove one 2.0 mm wafer screw from the SSD bracket.
  11. Dell XPS 15 9560 Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Pull out and separate the SSD bracket and SSD, replacing the old SSD with a new one.
  12. Dell XPS 15 9560 Motherboard Replacement, Wireless Card: stap 12, afbeelding 1 van 1
    • Using the Phillips #2 screwdriver, remove the single 4.0 mm screw securing the wireless card base to the motherboard.
  13. Dell XPS 15 9560 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Disconnect the wireless card cables from the wireless card.
  14. Dell XPS 15 9560 Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Slide the wireless card out of its slot.
  15. Dell XPS 15 9560 Motherboard Replacement, Fans: stap 15, afbeelding 1 van 1
    • Using a T5 Torx screwdriver, remove two 4.0 mm screws.
  16. Dell XPS 15 9560 Motherboard Replacement: stap 16, afbeelding 1 van 1
    • Unplug the fan cable.
  17. Dell XPS 15 9560 Motherboard Replacement: stap 17, afbeelding 1 van 1
    • Carefully remove the left-side fan.
  18. Dell XPS 15 9560 Motherboard Replacement: stap 18, afbeelding 1 van 1
  19. Dell XPS 15 9560 Motherboard Replacement: stap 19, afbeelding 1 van 1
    • Remove the right-side fan.
  20. Dell XPS 15 9560 Motherboard Replacement, RAM: stap 20, afbeelding 1 van 2 Dell XPS 15 9560 Motherboard Replacement, RAM: stap 20, afbeelding 2 van 2
    • Pull the metal clips surrounding the RAM stick outward.
    • The RAM will pop out.
    • Remove the RAM stick from the device.
  21. Dell XPS 15 9560 Motherboard Replacement, Motherboard: stap 21, afbeelding 1 van 1
    • Using a screwdriver, unscrew one 5.0 mm Torx T5 bracket screw.
    • Remove the bracket and unplug and loosen the LCD cable.
  22. Dell XPS 15 9560 Motherboard Replacement: stap 22, afbeelding 1 van 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws securing the motherboard to the device.
  23. Dell XPS 15 9560 Motherboard Replacement: stap 23, afbeelding 1 van 1
    • From right to left, unplug the bottom motherboard cables, DC jack cable, speaker cable.
  24. Dell XPS 15 9560 Motherboard Replacement: stap 24, afbeelding 1 van 1
    • Remove the motherboard.
Conclusie
Jada Houser
790 Reputatie
7 handleidingen geschreven
Clemson, Team 4-5, Hunter Fall 2021 Lid van Clemson, Team 4-5, Hunter Fall 2021
CLEM-HUNTER-F21S4G5
4 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 91
Altijd: 3,699
