Ga door naar hoofdinhoud
Dell XPS 15 9530 Base-Cover Assembly Replacement
Wat je nodig hebt
  1. Dell XPS 15 9530 Base-Cover Assembly Replacement, Unscrewing the Base-Cover Assembly: stap 1, afbeelding 1 van 1
    • After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
    • Don't forget to unscrew the two screws hidden under the system badge!
  2. Dell XPS 15 9530 Base-Cover Assembly Replacement, Prying Off the Base-Cover Assembly: stap 2, afbeelding 1 van 1
    • Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
William Daniels
824 Reputatie
6 handleidingen geschreven
2 opmerkingen
I need to replace these screws. What is the size, dimension, type?
Jason Benci - Antwoord
There is no "system badge" which folds open on my Dell XPS 15 9530 (2023). It is solid aluminum, and has "XPS" stamped into it. The images published for this repair guide appear as if the bottom cover is made of some kind of plastic? Am I looking at the wrong repair guide?
Tom Farrell - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 624
