Ga door naar hoofdinhoud
Dell XPS 15 9510 Headphone Jack Replacement
Wat je nodig hebt
  1. Dell XPS 15 9510 Headphone Jack Replacement, Rear Panel: stap 1, afbeelding 1 van 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Headphone Jack Replacement: stap 2, afbeelding 1 van 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Headphone Jack Replacement: stap 3, afbeelding 1 van 1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Headphone Jack Replacement, Headphone Jack: stap 4, afbeelding 1 van 2 Dell XPS 15 9510 Headphone Jack Replacement, Headphone Jack: stap 4, afbeelding 2 van 2
    • Remove three screws connecting the headphone jack to the back panel using a Phillips #00 screwdriver.
  5. Dell XPS 15 9510 Headphone Jack Replacement: stap 5, afbeelding 1 van 1
    • Carefully lift the headphone jack off the removed panel.
Conclusie
Austin Sa
432 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 1-3, Mellen Spring 2022 Lid van UMass Dartmouth, Team 1-3, Mellen Spring 2022
UMASSD-MELLEN-S22S1G3
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 1,189
