Ga door naar hoofdinhoud
Dell XPS 15 9500 Speaker Replacement
Wat je nodig hebt
  1. Dell XPS 15 9500 Speaker Replacement, Base Panel: stap 1, afbeelding 1 van 1
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 Speaker Replacement: stap 2, afbeelding 1 van 2 Dell XPS 15 9500 Speaker Replacement: stap 2, afbeelding 2 van 2
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
  3. Dell XPS 15 9500 Speaker Replacement, Speaker: stap 3, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the two 3.0 mm screws (one on each speaker).
    • Use an opening tool to lift out the speaker.
  4. Dell XPS 15 9500 Speaker Replacement: stap 4, afbeelding 1 van 2 Dell XPS 15 9500 Speaker Replacement: stap 4, afbeelding 2 van 2
    • Use an opening tool to push the left speaker's cable out of its port until it is disconnected.
    • The speaker on the right side isn't connected to the motherboard, and is only connected to the left speaker by a wire at the bottom.
Conclusie
Bryan Chung
437 Reputatie
4 handleidingen geschreven
UC Santa Barbara, Team A-1, Bator Winter 2022 Lid van UC Santa Barbara, Team A-1, Bator Winter 2022
UCSB-BATOR-W22SAG1
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 44
Altijd: 1,095
