Ga door naar hoofdinhoud
Dell XPS 15 9500 SSD Replacement
Wat je nodig hebt
  1. Dell XPS 15 9500 SSD Replacement, Base Panel: stap 1, afbeelding 1 van 1
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 SSD Replacement: stap 2, afbeelding 1 van 2 Dell XPS 15 9500 SSD Replacement: stap 2, afbeelding 2 van 2
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
  3. Dell XPS 15 9500 SSD Replacement, SSD: stap 3, afbeelding 1 van 1
    • Use a Phillips #000 screwdriver to remove the single 3.0 mm screw on the right side of the SSD.
  4. Dell XPS 15 9500 SSD Replacement: stap 4, afbeelding 1 van 1
    • Lift the card a few millimeters, then pull it directly out of its slot.
  5. Dell XPS 15 9500 SSD Replacement: stap 5, afbeelding 1 van 2 Dell XPS 15 9500 SSD Replacement: stap 5, afbeelding 2 van 2
    • If you wish to install a second SSD, there is an empty slot for an additional SSD underneath the copper cover. If you're just replacing the existing SSD, stop here.
    • Use a Phillips #000 screwdriver to remove the one 3.0 mm screw on the left side of the SSD slot.
    • Pull the cover out directly toward the left.
Conclusie
Bryan Chung
437 Reputatie
4 handleidingen geschreven
UC Santa Barbara, Team A-1, Bator Winter 2022 Lid van UC Santa Barbara, Team A-1, Bator Winter 2022
UCSB-BATOR-W22SAG1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 85
Altijd: 4,802
