Ga door naar hoofdinhoud
Dell XPS 14 L401X Keyboard Replacement
Wat je nodig hebt
  1. Dell XPS 14 L401X Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 Dell XPS 14 L401X Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure that the laptop is shut off before attempting to remove any components from the device.
    • The laptop in this example did not have a battery equipped.
    • Locate the spring latch on the bottom of the device that will unlatch the battery.
    • Hold the spring latch in the open position and pull the battery out of its recess.
  2. Dell XPS 14 L401X Keyboard Replacement, RAM: stap 2, afbeelding 1 van 3 Dell XPS 14 L401X Keyboard Replacement, RAM: stap 2, afbeelding 2 van 3 Dell XPS 14 L401X Keyboard Replacement, RAM: stap 2, afbeelding 3 van 3
    • Use a JIS 1 screwdriver to loosen the (2) captive screws from the panel.
    • The captive screws will not come off of the panel.
    • Pull the panel upwards and towards the battery to remove.
    • Put the panel to the side, exposing the RAM.
  3. Dell XPS 14 L401X Keyboard Replacement: stap 3, afbeelding 1 van 2 Dell XPS 14 L401X Keyboard Replacement: stap 3, afbeelding 2 van 2
    • The RAM is held by two spring clips. Pull at the two spring clips and the RAM will move upwards.
    • Keep your fingers on the edge of the chip.
    • Only handle the RAM by the sides! Do not touch the circuits or the terminals to avoid contamination!
  4. Dell XPS 14 L401X Keyboard Replacement, Optical Drive: stap 4, afbeelding 1 van 2 Dell XPS 14 L401X Keyboard Replacement, Optical Drive: stap 4, afbeelding 2 van 2
    • Locate and remove (1) 8.5mm JIS 1 screw at the top left corner of the RAM bay.
  5. Dell XPS 14 L401X Keyboard Replacement: stap 5, afbeelding 1 van 3 Dell XPS 14 L401X Keyboard Replacement: stap 5, afbeelding 2 van 3 Dell XPS 14 L401X Keyboard Replacement: stap 5, afbeelding 3 van 3
    • Carefully pull out the optical drive from its bay.
  6. Dell XPS 14 L401X Keyboard Replacement: stap 6, afbeelding 1 van 2 Dell XPS 14 L401X Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Carefully pull off the decorative cover from the front of the optical drive.
    • This decorative cover will be transferred to the new optical drive.
  7. Dell XPS 14 L401X Keyboard Replacement: stap 7, afbeelding 1 van 3 Dell XPS 14 L401X Keyboard Replacement: stap 7, afbeelding 2 van 3 Dell XPS 14 L401X Keyboard Replacement: stap 7, afbeelding 3 van 3
    • Use a JIS 1 screwdriver to remove (2) 2mm screws on the drive's anchoring bracket.
    • This bracket will be transferred to the new optical drive.
  8. Dell XPS 14 L401X Keyboard Replacement, Hard Drive: stap 8, afbeelding 1 van 2 Dell XPS 14 L401X Keyboard Replacement, Hard Drive: stap 8, afbeelding 2 van 2
    • Use a JIS 1 screwdriver to remove (2) 2.5mm screws located on the right side of the RAM bay.
  9. Dell XPS 14 L401X Keyboard Replacement: stap 9, afbeelding 1 van 2 Dell XPS 14 L401X Keyboard Replacement: stap 9, afbeelding 2 van 2
    • Push the hard drive to the right with a spudger to unseat it from its socket while pulling out the hard drive with your other hand.
  10. Dell XPS 14 L401X Keyboard Replacement: stap 10, afbeelding 1 van 3 Dell XPS 14 L401X Keyboard Replacement: stap 10, afbeelding 2 van 3 Dell XPS 14 L401X Keyboard Replacement: stap 10, afbeelding 3 van 3
    • Use a JIS 1 screwdriver to remove (1) 2.5mm screw attaching the plastic cosmetic cover to the hard drive.
    • Detach the plastic cosmetic cover from the hard drive.
    • This cosmetic cover will be transferred to the new hard drive.
  11. Dell XPS 14 L401X Keyboard Replacement, Mini Card: stap 11, afbeelding 1 van 3 Dell XPS 14 L401X Keyboard Replacement, Mini Card: stap 11, afbeelding 2 van 3 Dell XPS 14 L401X Keyboard Replacement, Mini Card: stap 11, afbeelding 3 van 3
    • Locate the mini card access panel marked with a radio tower emblem on the bottom of the laptop near the battery bay.
    • Use a JIS 1 screwdriver to loosen the captive screw securing the panel to the device.
    • The captive screw will not come off of the panel.
    • Carefully remove the panel by prying it upwards, unlocking it from the tabs that are securing it in place.
  12. Dell XPS 14 L401X Keyboard Replacement: stap 12, afbeelding 1 van 3 Dell XPS 14 L401X Keyboard Replacement: stap 12, afbeelding 2 van 3 Dell XPS 14 L401X Keyboard Replacement: stap 12, afbeelding 3 van 3
    • Disconnect the two wires on the mini card by carefully plucking them upwards by the metal contact points at the terminals.
    • Do not pluck the contacts off of the terminals by pulling on the wires, this can damage the cables.
    • Remove (1) 2mm screw from the bottom left corner of the mini card with a JIS 1 screwdriver.
  13. Dell XPS 14 L401X Keyboard Replacement: stap 13, afbeelding 1 van 2 Dell XPS 14 L401X Keyboard Replacement: stap 13, afbeelding 2 van 2
    • Remove the mini card as it flips upward.
  14. Dell XPS 14 L401X Keyboard Replacement, Palm Rest: stap 14, afbeelding 1 van 2 Dell XPS 14 L401X Keyboard Replacement, Palm Rest: stap 14, afbeelding 2 van 2
    • Remove two 4.5mm screws with JIS 1 screwdriver marked by the letter "K" in the optical drive bay.
  15. Dell XPS 14 L401X Keyboard Replacement: stap 15, afbeelding 1 van 2 Dell XPS 14 L401X Keyboard Replacement: stap 15, afbeelding 2 van 2
    • Remove (2) 4.5mm screws with JIS 1 screwdriver marked by the letter "K"in the hard drive bay.
  16. Dell XPS 14 L401X Keyboard Replacement: stap 16, afbeelding 1 van 2 Dell XPS 14 L401X Keyboard Replacement: stap 16, afbeelding 2 van 2
    • Remove (2) 4.5mm screws with JIS 1 screwdriver marked by the letter "K" near Battery
  17. Dell XPS 14 L401X Keyboard Replacement: stap 17, afbeelding 1 van 2 Dell XPS 14 L401X Keyboard Replacement: stap 17, afbeelding 2 van 2
    • Remove (1) 7.5mm screw with JIS 1 screwdriver marked by the letter "K" in the RAM bay.
  18. Dell XPS 14 L401X Keyboard Replacement: stap 18, afbeelding 1 van 3 Dell XPS 14 L401X Keyboard Replacement: stap 18, afbeelding 2 van 3 Dell XPS 14 L401X Keyboard Replacement: stap 18, afbeelding 3 van 3
    • Open the display to provide room for the palm rest to come out.
    • In the hard drive bay, push the "push" pad to lift up the palm rest.
  19. Dell XPS 14 L401X Keyboard Replacement: stap 19, afbeelding 1 van 3 Dell XPS 14 L401X Keyboard Replacement: stap 19, afbeelding 2 van 3 Dell XPS 14 L401X Keyboard Replacement: stap 19, afbeelding 3 van 3
    • Disconnect the track pad cable by flipping up the gray clamp and lifting the cable up.
  20. Dell XPS 14 L401X Keyboard Replacement: stap 20, afbeelding 1 van 2 Dell XPS 14 L401X Keyboard Replacement: stap 20, afbeelding 2 van 2
    • Disconnect the status bar cable by pulling the pin connector upward.
    • Finish lifting up the palm rest.
  21. Dell XPS 14 L401X Keyboard Replacement, Keyboard: stap 21, afbeelding 1 van 2 Dell XPS 14 L401X Keyboard Replacement, Keyboard: stap 21, afbeelding 2 van 2
    • Use a JIS 1 screwdriver to remove (2) 2.5mm screws located near the top of the keyboard.
  22. Dell XPS 14 L401X Keyboard Replacement: stap 22, afbeelding 1 van 3 Dell XPS 14 L401X Keyboard Replacement: stap 22, afbeelding 2 van 3 Dell XPS 14 L401X Keyboard Replacement: stap 22, afbeelding 3 van 3
    • Disconnect the keyboard's ribbon cable marked "A" by pushing out the two black tabs towards the ribbon cable.
    • Remove the cable from its connection terminal by sliding it out. Finish lifting up the keyboard and set it to the side.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nicole Johnson
428 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S4-G3, Julie Fall 2017 Lid van UMass Dartmouth, Team S4-G3, Julie Fall 2017
UMASSD-JULIE-F17S4G3
3 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 836
