Ga door naar hoofdinhoud
Dell XPS 1340 CPU Fan Replacement
Wat je nodig hebt
  1. Dell XPS 1340 CPU Fan Replacement, CPU Fan: stap 1, afbeelding 1 van 1
    • Remove the battery by sliding the battery lock switch
  2. Dell XPS 1340 CPU Fan Replacement: stap 2, afbeelding 1 van 1
    • Remove the lower panel of the laptop by loosening 10 screws. Note that the screws do no come out of the back panel.
  3. Dell XPS 1340 CPU Fan Replacement: stap 3, afbeelding 1 van 1
    • Remove two screws which holds a smaller back panel covering only the heatsink
  4. Dell XPS 1340 CPU Fan Replacement: stap 4, afbeelding 1 van 2 Dell XPS 1340 CPU Fan Replacement: stap 4, afbeelding 2 van 2
    • Loosen the four screws on the heat sink for the CPU. Note that these screws don't come out.
    • Now carefully lift the unit from holding the heat pipe.
    • After the heat-pipe unit is removed, the power connector for the fan is accessible.
  5. Dell XPS 1340 CPU Fan Replacement: stap 5, afbeelding 1 van 2 Dell XPS 1340 CPU Fan Replacement: stap 5, afbeelding 2 van 2
    • First remove the power connector for the CPU Fan.
    • Now remove the two screws connecting the CPU Fan.
    • Slowly slide the CPU Fan upwards. It would be a little tight around the edges.
  6. Dell XPS 1340 CPU Fan Replacement: stap 6, afbeelding 1 van 1
    • Unpack the new fan. Make sure the power wires are fixed in the hook provided.
    • Follow all step backwards and finish.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Paras Tolani
188 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 2,806
