Ga door naar hoofdinhoud
Dell XPS 13 9370 Battery Replacement
Wat je nodig hebt
    • Save and close all open files and exit all open applications.
    • Shut down your computer. Click Start > Power > Shut down.
    • Disconnect your computer and all attached devices from their electrical outlets.
    • Disconnect all attached network devices and peripherals, such as keyboard, mouse, and monitor from your computer.
    • Remove any media card and optical disc from your computer, if applicable.
  1. Dell XPS 13 9370 Battery Replacement, Remove the base cover screws: stap 2, afbeelding 1 van 1
    • Remove the eight screws (M2x3, Torx) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9370 Battery Replacement, Remove the base cover: stap 3, afbeelding 1 van 2 Dell XPS 13 9370 Battery Replacement, Remove the base cover: stap 3, afbeelding 2 van 2
    • With the computer face-down, open the computer at an angle.
    • Using a plastic scribe (spudger), pry the base cover from the palm-rest assembly.
    • Moving the base cover from left to right, release the clips securing the base cover to the palm-rest assembly.
    • Lift the base cover from the palm-rest assembly.
  3. Dell XPS 13 9370 Battery Replacement, Disconnect battery cable: stap 4, afbeelding 1 van 1
    • Disconnect the battery cable from the system board.
  4. Dell XPS 13 9370 Battery Replacement, Remove the battery: stap 5, afbeelding 1 van 1
    • Remove the four screws (M2x2) that secure the battery to the palm-rest assembly.
    • Remove the screw (M1.6x4) that secures the battery to the palm-rest assembly.
    • Lift the battery off the palm-rest assembly.
    • Turn the computer over, open the display, and press the power button for about 5 seconds to ground the computer.
Conclusie
To replace the battery & reassemble your device, follow these instructions in reverse order.
23 andere personen hebben deze handleiding voltooid.
Max Kletskov
40.298 Reputatie
16 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
17.198 handleidingen geschreven
8 opmerkingen
Is the battery an original dell battery?
mnyousafva - Antwoord
Why doesn’t it say what tools are needed?
Noah Guirguis - Antwoord
Excellent guide. Took me about 25 minutes. Works perfectly.
Jeff Doremus - Antwoord
Instructions were perfect, thanks for the great guide!
surfdaworld - Antwoord
Boom, in a good way! I fixed it!
Chris Cox - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 93
Afgelopen 30 dagen: 501
Altijd: 15,294
