Inleiding
Use this guide to remove or replace the touchpad on your Dell XPS 13 9365 2-in-1 laptop. This is a simple and quick guide, but take care in handling the fragile touchpad cable when you disconnect it.
Wat je nodig hebt
Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
Open the ZIF latch on the touch pad connector.
Disconnect and remove the ribbon cable from the touch pad. The ZIF connector latch lifts up to allow its release.
