Ga door naar hoofdinhoud
Dell XPS 13 9365 2-in-1 Touchpad Replacement
Wat je nodig hebt
  1. Dell XPS 13 9365 2-in-1 Touchpad Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Touchpad Replacement: stap 2, afbeelding 1 van 1
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Touchpad Replacement: stap 3, afbeelding 1 van 1
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Touchpad Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Touchpad Replacement: stap 5, afbeelding 1 van 1
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Touchpad Replacement: stap 6, afbeelding 1 van 1
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Touchpad Replacement: stap 7, afbeelding 1 van 1
    • Lift the battery off the palm-rest assembly.
  8. Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: stap 8, afbeelding 1 van 3 Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: stap 8, afbeelding 2 van 3 Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: stap 8, afbeelding 3 van 3
    • Open the ZIF latch on the touch pad connector.
    • Disconnect and remove the ribbon cable from the touch pad. The ZIF connector latch lifts up to allow its release.
  9. Dell XPS 13 9365 2-in-1 Touchpad Replacement: stap 9, afbeelding 1 van 1
    • Use a Phillips #000 screwdriver to remove the two screws (M2x2) that secure the touch pad to the palm-rest assembly.
  10. Dell XPS 13 9365 2-in-1 Touchpad Replacement: stap 10, afbeelding 1 van 2 Dell XPS 13 9365 2-in-1 Touchpad Replacement: stap 10, afbeelding 2 van 2
    • Lift the touch pad from the inner edge and remove it from the palm-rest assembly.
Conclusie
Melissa Schlein
686 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 19
Altijd: 626
