Ga door naar hoofdinhoud
Dell XPS 13 9365 2-in-1 Speakers Replacement
Wat je nodig hebt
  1. Dell XPS 13 9365 2-in-1 Speakers Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Speakers Replacement: stap 2, afbeelding 1 van 1
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Speakers Replacement: stap 3, afbeelding 1 van 1
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Speakers Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Speakers Replacement: stap 5, afbeelding 1 van 1
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Speakers Replacement: stap 6, afbeelding 1 van 1
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Speakers Replacement: stap 7, afbeelding 1 van 1
    • Lift the battery off the palm-rest assembly.
  8. Dell XPS 13 9365 2-in-1 Speakers Replacement, Speakers: stap 8, afbeelding 1 van 1
    • Peel off the tape securing the speaker cable to the system board.
  9. Dell XPS 13 9365 2-in-1 Speakers Replacement: stap 9, afbeelding 1 van 1
    • Disconnect the speaker cable from the motherboard.
  10. Dell XPS 13 9365 2-in-1 Speakers Replacement: stap 10, afbeelding 1 van 1
    • Note the speaker-cable routing and peel off the tape that secures the speaker cable to the system board.
  11. Dell XPS 13 9365 2-in-1 Speakers Replacement: stap 11, afbeelding 1 van 2 Dell XPS 13 9365 2-in-1 Speakers Replacement: stap 11, afbeelding 2 van 2
    • Use a Phillips #000 screwdriver to remove the four screws (M2x2) that secure the speakers to the palm-rest assembly.
  12. Dell XPS 13 9365 2-in-1 Speakers Replacement: stap 12, afbeelding 1 van 1
    • Lift the speakers, along with its cables, off the palm-rest assembly.
Conclusie
Melissa Schlein
701 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 483
