Ga door naar hoofdinhoud
Dell XPS 12 9Q23 Battery Replacement
Wat je nodig hebt
  1. Dell XPS 12 9Q23 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Pop the center cover open on the bottom cover.
    • Remove the center screw with a #00 Phillips screwdriver.
    • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
  2. Dell XPS 12 9Q23 Battery Replacement: stap 2, afbeelding 1 van 1
    • Carefully remove back panel after all screws have been removed.
  3. Dell XPS 12 9Q23 Battery Replacement: stap 3, afbeelding 1 van 1
    • After the back panel has been removed, disconnect the battery to prevent electrical shock
  4. Dell XPS 12 9Q23 Battery Replacement: stap 4, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
  5. Dell XPS 12 9Q23 Battery Replacement, Remove the battery: stap 5, afbeelding 1 van 1
    • Once all the screws have been removed the battery is now safe to extract
Conclusie
5 andere personen hebben deze handleiding voltooid.
Kyle Yatsula
162 Reputatie
1 Handleiding geschreven
2 opmerkingen
Any tips for registering the new battery in the BIOS?
Ryan Porter - Antwoord
Your battery is automatically recognized.
There is no declaration to be made in the bios.
If the problem persists, I invite you to open a support question:
https://fr.ifixit.com/R%C3%A9ponses/Devi...
Schwarzer -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 40
Altijd: 4,411
