Inleiding
With the required tools and time, a Dell XPS 10 can be fixed in under an hour.
"Do not use metal tools to pry connectors off the board. You can cause a short circuit and fry your motherboard if you do so."
Wat je nodig hebt
Slide one of the plastic opening tools in the crack on the side of the device with the windows button.
Slide the other plastic opening tool facing the opposite way in the crack next to the first one and pry the back cover off a little bit at a time or slide them around the edge as necessary.
Finally, slide the two plastic opening tools all around the case until it is open.
Unscrew the three black, 4mm screws with a phillips screwdriver size PH 0 (one of which is under the gold colored ribbon cable.)
Unscrew the three gray, 3mm screws with the same screwdriver (phillips screwdriver size PH 0.)
Unplug the connector the connects the battery to the mother board.
Unscrew the two screws shown circled in red in the picture.
Use a #0 Phillips screwdriver to remove the two 4 mm screws
Lift up the plug that connects the camera to the motherboard using the plastic opening tool as shown in the pictures.
Use the black spudger to remove all of the ribbon cables except for the wide orange cable.
Use a plastic opening tool to remove the orange cable.
Use a #0 Phillips screwdriver to remove the two 3 mm screws.
Één andere persoon heeft deze handleiding voltooid.
