Ga door naar hoofdinhoud
Dell XPS 10 Front and Rear Camera Replacement
Wat je nodig hebt
  1. Dell XPS 10 Front and Rear Camera Replacement, Front and Rear Camera: stap 1, afbeelding 1 van 3 Dell XPS 10 Front and Rear Camera Replacement, Front and Rear Camera: stap 1, afbeelding 2 van 3 Dell XPS 10 Front and Rear Camera Replacement, Front and Rear Camera: stap 1, afbeelding 3 van 3
    • Unscrew the two screws shown circled in red in the picture.
    • Use a #0 Phillips screwdriver to remove the two 4 mm screws
    • Lift up the plug that connects the camera to the motherboard using the plastic opening tool as shown in the pictures.
  2. Dell XPS 10 Front and Rear Camera Replacement: stap 2, afbeelding 1 van 2 Dell XPS 10 Front and Rear Camera Replacement: stap 2, afbeelding 2 van 2
    • After the rear facing camera is removed, you may now remove the front facing camera.
    • Use the nylon spudger to disconnect the cable on the motherboard.
    • Make sure you use the black plastic spudger to pry up the aluminum tape holding the front facing camera. Be careful as the tape is fragile.
Conclusie
James
401 Reputatie
3 handleidingen geschreven
USF Tampa, Team 2-1, Nance Fall 2016 Lid van USF Tampa, Team 2-1, Nance Fall 2016
USFT-NANCE-F16S2G1
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 332
