Ga door naar hoofdinhoud
Dell XPS 10 Battery Replacement
Wat je nodig hebt
  1. Dell XPS 10 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Dell XPS 10 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Dell XPS 10 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Slide one of the plastic opening tools in the crack on the side of the device with the windows button.
    • Slide the other plastic opening tool facing the opposite way in the crack next to the first one and pry the back cover off a little bit at a time or slide them around the edge as necessary.
    • Finally, slide the two plastic opening tools all around the case until it is open.
  2. Dell XPS 10 Battery Replacement: stap 2, afbeelding 1 van 3 Dell XPS 10 Battery Replacement: stap 2, afbeelding 2 van 3 Dell XPS 10 Battery Replacement: stap 2, afbeelding 3 van 3
    • Unscrew the three black, 4mm screws with a phillips screwdriver size PH 0 (one of which is under the gold colored ribbon cable.)
    • Unscrew the three gray, 3mm screws with the same screwdriver (phillips screwdriver size PH 0.)
    • Unplug the connector the connects the battery to the mother board.
    • Make sure to use a plastic opening tool instead of a metal spudger to avoid any unnecessary accidental shorting out of components.
Conclusie
saraspam
244 Reputatie
2 handleidingen geschreven
USF Tampa, Team 2-1, Nance Fall 2016 Lid van USF Tampa, Team 2-1, Nance Fall 2016
USFT-NANCE-F16S2G1
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 3,149
