Inleiding
You can follow these steps to replace the sound card in your Dell Vostro V13. Be sure to power down, unplug and also back-up your laptop in order to prevent injury and loss of data.
Wat je nodig hebt
Flip the laptop over so the vents are facing you.
Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
Remove the two 5.0 mm Phillips #1 screws on the back side of the laptop.
Remove the black 3.0 mm Phillips #1 screw.
Remove the two 5.1 mm silver Phillips #1 screws.
