Ga door naar hoofdinhoud
Dell Vostro V13 Back Cover and Battery Removal
Wat je nodig hebt
  1. Dell Vostro V13  Back Cover and Battery Removal, Back Cover: stap 1, afbeelding 1 van 3 Dell Vostro V13  Back Cover and Battery Removal, Back Cover: stap 1, afbeelding 2 van 3 Dell Vostro V13  Back Cover and Battery Removal, Back Cover: stap 1, afbeelding 3 van 3
    • Back up the memory to an external drive and power off the laptop before starting.
    • Flip the laptop over so the vents are facing you.
    • Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
    • Remove the two 5.0 mm Phillips #1 screws on the back side of the laptop.
  2. Dell Vostro V13  Back Cover and Battery Removal: stap 2, afbeelding 1 van 3 Dell Vostro V13  Back Cover and Battery Removal: stap 2, afbeelding 2 van 3 Dell Vostro V13  Back Cover and Battery Removal: stap 2, afbeelding 3 van 3
    • Slide out the SD and MicroSD holders.
    • If you are having trouble sliding them out, use the plastic opening tool.
  3. Dell Vostro V13  Back Cover and Battery Removal: stap 3, afbeelding 1 van 3 Dell Vostro V13  Back Cover and Battery Removal: stap 3, afbeelding 2 van 3 Dell Vostro V13  Back Cover and Battery Removal: stap 3, afbeelding 3 van 3
    • Slide the plastic opening tool around the perimeter of the laptop until the cover pops off.
    • Pull the back cover off.
  4. Dell Vostro V13  Back Cover and Battery Removal: stap 4, afbeelding 1 van 2 Dell Vostro V13  Back Cover and Battery Removal: stap 4, afbeelding 2 van 2
    • Remove the three black 3.9 mm Phillips #1 screws holding the battery in place.
  5. Dell Vostro V13  Back Cover and Battery Removal: stap 5, afbeelding 1 van 3 Dell Vostro V13  Back Cover and Battery Removal: stap 5, afbeelding 2 van 3 Dell Vostro V13  Back Cover and Battery Removal: stap 5, afbeelding 3 van 3
    • Flip up the clip of the ribbon connector.
    • Pull the strip out to disconnect the battery.
  6. Dell Vostro V13  Back Cover and Battery Removal: stap 6, afbeelding 1 van 2 Dell Vostro V13  Back Cover and Battery Removal: stap 6, afbeelding 2 van 2
    • Remove the battery.
    • Removing the battery allows you to work safely.
Conclusie
Patrick Swaney
363 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 387
