Ga door naar hoofdinhoud
Dell Vostro 5560 Memory Module Replacement
Wat je nodig hebt
  1. Dell Vostro 5560 Memory Module Replacement, Removing The Optical-Disk Drive: stap 1, afbeelding 1 van 1
    • Remove the screw that secures the base cover to the computer.
    • Pull the optical-drive and remove from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro 5560 Memory Module Replacement, Replacing the Base Cover: stap 2, afbeelding 1 van 2 Dell Vostro 5560 Memory Module Replacement, Replacing the Base Cover: stap 2, afbeelding 2 van 2
    • Remove the screws that secure the base cover to the computer.
    • Pry the base cover along the edges to loosen it. Lift and remove the base cover from the computer.
  3. Dell Vostro 5560 Memory Module Replacement, Removing the Battery: stap 3, afbeelding 1 van 1
    • Disconnect the battery cable from its connector on the system board.
    • Lift and remove the battery from the computer.
  4. Dell Vostro 5560 Memory Module Replacement, Removing the Memory Module: stap 4, afbeelding 1 van 1
    • Pry the securing clips away from the memory module until it pops-up. Remove the memory module from its connector on the system board.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Johnathan Hammond
45.624 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
44 Leden
1.997 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 8
Altijd: 193
