Ga door naar hoofdinhoud
Dell Vostro 5560 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Vostro 5560 Hard Drive Replacement, Removing The Optical-Disk Drive: stap 1, afbeelding 1 van 1
    • Remove the screw that secures the base cover to the computer.
    • Pull the optical-drive and remove from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro 5560 Hard Drive Replacement, Replacing the Base Cover: stap 2, afbeelding 1 van 2 Dell Vostro 5560 Hard Drive Replacement, Replacing the Base Cover: stap 2, afbeelding 2 van 2
    • Remove the screws that secure the base cover to the computer.
    • Pry the base cover along the edges to loosen it. Lift and remove the base cover from the computer.
  3. Dell Vostro 5560 Hard Drive Replacement, Removing the Battery: stap 3, afbeelding 1 van 1
    • Disconnect the battery cable from its connector on the system board.
    • Lift and remove the battery from the computer.
  4. Dell Vostro 5560 Hard Drive Replacement, Disconnecting the Hard Drive: stap 4, afbeelding 1 van 1
    • Ease the I/O cable from the routing tabs.
    • Disconnect the hard-drive cable from the system board and remove the screws that secures the hard-drive in place
    • Lift and remove the hard-drive from the computer
  5. Dell Vostro 5560 Hard Drive Replacement, Disconnecting the Hard Drive Connector: stap 5, afbeelding 1 van 1
    • Disconnect the hard-drive connector from hard drive.
  6. Dell Vostro 5560 Hard Drive Replacement, Remove the Screws: stap 6, afbeelding 1 van 1
    • Remove the screws that secure the hard-drive bracket to the hard drive. Separate the hard-drive bracket from the hard drive.
Eindstreep
Johnathan Hammond
45.237 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 239
