Ga door naar hoofdinhoud
Dell Vostro 5510 Speakers Replacement
Wat je nodig hebt
  1. Dell Vostro 5510 Speakers Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Power off your laptop before beginning disassembly.
    • Place the laptop so the bottom cover is facing upwards.
  2. Dell Vostro 5510 Speakers Replacement: stap 2, afbeelding 1 van 1
    • Remove the remaining (M2x4mm) screws with the screwdriver.
    • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
  3. Dell Vostro 5510 Speakers Replacement: stap 3, afbeelding 1 van 3 Dell Vostro 5510 Speakers Replacement: stap 3, afbeelding 2 van 3 Dell Vostro 5510 Speakers Replacement: stap 3, afbeelding 3 van 3
    • Pry open the top left corner of the cover with the opening tool.
    • Pry open the top right corner of the cover with the opening tool.
    • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
  4. Dell Vostro 5510 Speakers Replacement: stap 4, afbeelding 1 van 3 Dell Vostro 5510 Speakers Replacement: stap 4, afbeelding 2 van 3 Dell Vostro 5510 Speakers Replacement: stap 4, afbeelding 3 van 3
    • Lift the cover to remove it from the rest of the laptop.
  5. Dell Vostro 5510 Speakers Replacement, Battery: stap 5, afbeelding 1 van 1
    • Unscrew the corner and top middle screws (M2x3mm) from the battery with the screwdriver.
  6. Dell Vostro 5510 Speakers Replacement: stap 6, afbeelding 1 van 3 Dell Vostro 5510 Speakers Replacement: stap 6, afbeelding 2 van 3 Dell Vostro 5510 Speakers Replacement: stap 6, afbeelding 3 van 3
    • Lift the battery to remove it
  7. Dell Vostro 5510 Speakers Replacement, Speakers: stap 7, afbeelding 1 van 2 Dell Vostro 5510 Speakers Replacement, Speakers: stap 7, afbeelding 2 van 2
    • Remove the 4 mm screw from metal plate above the right-side speaker using a Phillips #0 screwdriver.
  8. Dell Vostro 5510 Speakers Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the orange cable securing the speaker cords gently using tweezers.
  9. Dell Vostro 5510 Speakers Replacement: stap 9, afbeelding 1 van 2 Dell Vostro 5510 Speakers Replacement: stap 9, afbeelding 2 van 2
    • Push the thin white clip back using your finger to release the blue cable.
    • Disconnect the thick blue cable gently using tweezers.
  10. Dell Vostro 5510 Speakers Replacement: stap 10, afbeelding 1 van 1
    • Disconnect the thin blue cable by gently pulling with tweezers.
  11. Dell Vostro 5510 Speakers Replacement: stap 11, afbeelding 1 van 1
    • Pull the left speaker up using your hand.
  12. Dell Vostro 5510 Speakers Replacement: stap 12, afbeelding 1 van 1
    • Pull the right speaker up using your hand.
  13. Dell Vostro 5510 Speakers Replacement: stap 13, afbeelding 1 van 1
    • Lift the thin cords from under the cable and other components to disconnect them using your hand.
  14. Dell Vostro 5510 Speakers Replacement: stap 14, afbeelding 1 van 1
    • Pull the white part of the box connecting the speaker cords to the computer using your finger.
Conclusie
Simon
157 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 43
