Ga door naar hoofdinhoud
Dell Vostro 5480 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Vostro 5480 Hard Drive Replacement, Remove the Screws: stap 1, afbeelding 1 van 1
    • Remove the screws that secure the base cover to the computer.
  2. Dell Vostro 5480 Hard Drive Replacement, Pry the Cover: stap 2, afbeelding 1 van 1
    • Pry the base cover along the edges to loosen it.
  3. Dell Vostro 5480 Hard Drive Replacement, Removing the Base Cover: stap 3, afbeelding 1 van 1
    • Lift and remove the base cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  4. Dell Vostro 5480 Hard Drive Replacement, Disconnecting the Battery Cable: stap 4, afbeelding 1 van 1
    • Disconnect the battery cable from its connector on the system board.
  5. Dell Vostro 5480 Hard Drive Replacement, Release the Tabs: stap 5, afbeelding 1 van 1
    • Release the tabs that secure the battery in the battery bay.
  6. Dell Vostro 5480 Hard Drive Replacement, Removing the Battery: stap 6, afbeelding 1 van 1
    • Lift and remove the battery from the computer.
  7. Dell Vostro 5480 Hard Drive Replacement, Removing the Hard Drive: stap 7, afbeelding 1 van 1
    • Lift the hard drive assembly in an upward direction to release it from its compartment on the computer. Remove the hard drive from the computer.
  8. Dell Vostro 5480 Hard Drive Replacement, Remove the Screws: stap 8, afbeelding 1 van 1
    • Remove the screws that secure the hard drive to the hard drive assembly.
    • Lift and remove the hard drive from the hard drive assembly.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Johnathan Hammond
45.237 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 1,344
