Ga door naar hoofdinhoud
Dell Vostro 5459 Memory Module Replacement
Wat je nodig hebt
  1. Dell Vostro 5459 Memory Module Replacement, Removing the Base Cover: stap 1, afbeelding 1 van 1
    • Remove the screws that secure the back cover to the computer.
    • Pry the edges of the back cover from all sides, to release the back cover.
    • Lift the back cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro 5459 Memory Module Replacement, Removing the Battery: stap 2, afbeelding 1 van 1
    • Disconnect the battery cable from the connector on the system board [1].
    • Remove the screws that secure the battery to the computer [2].
    • Lift and remove the battery from the computer [3].
  3. Dell Vostro 5459 Memory Module Replacement, Removing the Memory Module: stap 3, afbeelding 1 van 1
    • Lift the plastic enclosure covering the top of the memory module compartment.
    • Pull the retention clips from the memory module until it pops up.
    • Remove the memory module from the connector on the system board.
Conclusie
Johnathan Hammond
46.149 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
45 Leden
2.002 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 43
Altijd: 436
