Ga door naar hoofdinhoud
Dell Vostro 3558 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Vostro 3558 Hard Drive Replacement, Unlocking the Battery: stap 1, afbeelding 1 van 1
    • Slide the release latch outwards to unlock the battery.
  2. Dell Vostro 3558 Hard Drive Replacement, Removing the Battery: stap 2, afbeelding 1 van 1
    • Remove the battery from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Dell Vostro 3558 Hard Drive Replacement, Access Panel: stap 3, afbeelding 1 van 1
    • Remove the screws that secure the access panel to the computer [1].
    • Lift the access panel partially at a 45–degree angle [2].
  4. Dell Vostro 3558 Hard Drive Replacement, Remove the Access Panel: stap 4, afbeelding 1 van 1
    • Remove the access panel from the computer.
  5. Dell Vostro 3558 Hard Drive Replacement, Disconnecting the Hard Drive Cable: stap 5, afbeelding 1 van 1
    • Disconnect the hard drive cable from the system board and lift it up to remove it from the computer.
    • Remove the screws that secure the hard drive to the computer.
  6. Dell Vostro 3558 Hard Drive Replacement, Lifting the Hard Drive: stap 6, afbeelding 1 van 1
    • Lift the hard drive to remove it from the computer.
  7. Dell Vostro 3558 Hard Drive Replacement, Removing the Hard Drive: stap 7, afbeelding 1 van 1
    • Remove the screws that secure the hard drive to the bracket.
    • Lift the hard drive from the bracket.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Johnathan Hammond
45.189 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
Één opmerking
Hello. Which hard drive is suitable for replacement of this particular one because mine is no longer working and I don't know anything about hard drive replacements
Noblesse Mukendi - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 11
Altijd: 940
