Ga door naar hoofdinhoud
Dell Vostro 3500 CD/DVD drive Replacement
Wat je nodig hebt
  1. Dell Vostro 3500 CD/DVD drive Replacement, Sliding the Battery Latch: stap 1, afbeelding 1 van 1
    • Flip the computer over.
    • Slide the battery release latch to the unlock position.
  2. Dell Vostro 3500 CD/DVD drive Replacement, Sliding the Battery Release Latch: stap 2, afbeelding 1 van 1
    • Slide the other battery release latch to the unlock position.
  3. Dell Vostro 3500 CD/DVD drive Replacement, Removing the Battery: stap 3, afbeelding 1 van 1
    • Slide the battery and remove it from the computer.
  4. Dell Vostro 3500 CD/DVD drive Replacement, Remove the Screws: stap 4, afbeelding 1 van 1
    • Turn the laptop over and remove two screws securing the service cover.
  5. Dell Vostro 3500 CD/DVD drive Replacement, Removing the Base Cover: stap 5, afbeelding 1 van 1
    • Prise up the service cover and remove it from the computer. Clips along the edges can be snapped open except for those on the left hand edge (as shown in the photo) which have to be disengaged after all the others by romoving the cover in the direction shown.
    • On resassembly, insert the clips on the left hand edge then snap all te others home by applying firm pressure along the other edges of the cover.
  6. Dell Vostro 3500 CD/DVD drive Replacement, CD/DVD drive removal: stap 6, afbeelding 1 van 1
    • Remove a single screw from under the service cover.
    • You should now be able to slide the CD/DVD drive out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Philip Le Riche
30.768 Reputatie
47 handleidingen geschreven
Restart Project Lid van Restart Project
Local Repair Groups
23 Leden
660 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 17
Altijd: 578
