Ga door naar hoofdinhoud
Dell Vostro 3450 System Board Replacement
Wat je nodig hebt
  1. Dell Vostro 3450 System Board Replacement, Unlocking the Battery: stap 1, afbeelding 1 van 1
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 System Board Replacement, Removing the Battery: stap 2, afbeelding 1 van 1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 System Board Replacement, Press the ExpressCard: stap 3, afbeelding 1 van 1
    • Press the ExpressCard to release it from the computer.
  4. Dell Vostro 3450 System Board Replacement, Slide the ExpressCard: stap 4, afbeelding 1 van 1
    • Slide the ExpressCard out of the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  5. Dell Vostro 3450 System Board Replacement, Prying the Keyboard: stap 5, afbeelding 1 van 1
    • Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
  6. Dell Vostro 3450 System Board Replacement, Prying the Keyboard retainer: stap 6, afbeelding 1 van 1
    • Pry up the second keyboard retainer.
  7. Dell Vostro 3450 System Board Replacement, Pry up the Keyboard Retainer: stap 7, afbeelding 1 van 1
    • Pry up the third keyboard retainer.
  8. Dell Vostro 3450 System Board Replacement, Prying the Retainer: stap 8, afbeelding 1 van 1
    • Pry up the fourth keyboard retainer.
  9. Dell Vostro 3450 System Board Replacement, Pull up the Keyboard: stap 9, afbeelding 1 van 1
    • Pull up the keyboard from the palm rest.
  10. Dell Vostro 3450 System Board Replacement, Release the Latch: stap 10, afbeelding 1 van 1
    • Release the latch on the system board connector, then disconnect the keyboard cable.
  11. Dell Vostro 3450 System Board Replacement, Loosen the Screw: stap 11, afbeelding 1 van 1
    • Loosen the screw that secures the memory door.
  12. Dell Vostro 3450 System Board Replacement, Removing the Memory Door: stap 12, afbeelding 1 van 1
    • Pry up the memory door near the screw hole, lift and remove it.
  13. Dell Vostro 3450 System Board Replacement, Remove the Screw: stap 13, afbeelding 1 van 1
    • Remove the screw that secures the optical drive to the computer.
  14. Dell Vostro 3450 System Board Replacement, Prying the Drive: stap 14, afbeelding 1 van 1
    • Gently pry the optical drive out of the computer.
  15. Dell Vostro 3450 System Board Replacement, Remove the Screws: stap 15, afbeelding 1 van 1
    • Remove the screws that secure the optical drive bracket.
  16. Dell Vostro 3450 System Board Replacement, Removing the Optical Drive: stap 16, afbeelding 1 van 1
    • Remove the optical drive bracket from the optical drive module.
  17. Dell Vostro 3450 System Board Replacement, Remove the Screws: stap 17, afbeelding 1 van 1
    • Remove the screws in the battery compartment.
  18. Dell Vostro 3450 System Board Replacement, Remove the Screws: stap 18, afbeelding 1 van 1
    • Remove the screws in the optical drive compartment.
  19. Dell Vostro 3450 System Board Replacement, Remove the Rubber: stap 19, afbeelding 1 van 1
    • Remove the rubber from the bottom base on the right side.
  20. Dell Vostro 3450 System Board Replacement, Remove the Rubber: stap 20, afbeelding 1 van 1
    • Remove the rubber from the bottom base on the left side.
  21. Dell Vostro 3450 System Board Replacement, Remove the Screws: stap 21, afbeelding 1 van 1
    • Remove all the screws from the bottom base.
  22. Dell Vostro 3450 System Board Replacement, Remove the Screws: stap 22, afbeelding 1 van 1
    • Flip the computer around and remove the screws that secures the palm rest.
  23. Dell Vostro 3450 System Board Replacement, Release the Latches: stap 23, afbeelding 1 van 1
    • Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
  24. Dell Vostro 3450 System Board Replacement, Release the Latch: stap 24, afbeelding 1 van 1
    • Release the latch on the system board connector and then disconnect the power button cable.
  25. Dell Vostro 3450 System Board Replacement, Disconnecting the Key Cable: stap 25, afbeelding 1 van 1
    • Release the latch on the system board connector and then disconnect the hot key cable.
  26. Dell Vostro 3450 System Board Replacement, Prying the Palm Rest: stap 26, afbeelding 1 van 1
    • Pry up the right side of the palm rest.
  27. Dell Vostro 3450 System Board Replacement, Prying the Palm Rest: stap 27, afbeelding 1 van 1
    • Pry up the left side of the palm rest.
  28. Dell Vostro 3450 System Board Replacement, Prying the Sides: stap 28, afbeelding 1 van 1
    • Pry up the sides of the palm rest and remove it from the computer.
  29. Dell Vostro 3450 System Board Replacement, Remove the Screws: stap 29, afbeelding 1 van 1
    • Remove the screws that secure the hinge cover.
  30. Dell Vostro 3450 System Board Replacement, Press Down on the Hooks: stap 30, afbeelding 1 van 1
    • Press down on the hooks highlighted in the image.
  31. Dell Vostro 3450 System Board Replacement, Removing the Hinge Cover: stap 31, afbeelding 1 van 1
    • Flip the computer around and remove the hinge cover from the side.
  32. Dell Vostro 3450 System Board Replacement, Remove the Screws: stap 32, afbeelding 1 van 1
    • Remove the screws that secure the display hinge.
  33. Dell Vostro 3450 System Board Replacement, Loosen the Screw: stap 33, afbeelding 1 van 1
    • Loosen the screw that secures the low-voltage differential signaling (LVDS) cable.
  34. Dell Vostro 3450 System Board Replacement, Disconnecting the LVDS Cable: stap 34, afbeelding 1 van 1
    • Disconnect the LVDS cable from the system board.
  35. Dell Vostro 3450 System Board Replacement, Disconnecting the Wireless Cables: stap 35, afbeelding 1 van 1
    • Disconnect the wireless local area network (WLAN) antenna cable.
  36. Dell Vostro 3450 System Board Replacement, Remove the Screws: stap 36, afbeelding 1 van 1
    • Remove the screws that secure the left hinge.
  37. Dell Vostro 3450 System Board Replacement, Remove the Screws: stap 37, afbeelding 1 van 1
    • Remove the screws that secure the right hinge.
  38. Dell Vostro 3450 System Board Replacement, Lifting the Display Assembly: stap 38, afbeelding 1 van 1
    • Lift the display assembly and remove it from the computer.
  39. Dell Vostro 3450 System Board Replacement, Remove the Screw: stap 39, afbeelding 1 van 1
    • Remove the screw that secures the WLAN card.
  40. Dell Vostro 3450 System Board Replacement, Pull the Card: stap 40, afbeelding 1 van 1
    • Pull the WLAN card straight out of its socket and remove it.
  41. Dell Vostro 3450 System Board Replacement, Release the Latch: stap 41, afbeelding 1 van 1
    • Release the latch on the system board and then disconnect the VGA cable.
  42. Dell Vostro 3450 System Board Replacement, Remove the Screw: stap 42, afbeelding 1 van 1
    • Remove the screw that secures the VGA board.
  43. Dell Vostro 3450 System Board Replacement, Remove the VGA Board: stap 43, afbeelding 1 van 1
    • Remove the VGA board from the chassis.
  44. Dell Vostro 3450 System Board Replacement, Disconnect the System Fan Cable: stap 44, afbeelding 1 van 1
    • Disconnect the system fan cable from the system board.
  45. Dell Vostro 3450 System Board Replacement, Remove the Screw: stap 45, afbeelding 1 van 1
    • Remove the screw that secures the system fan.
  46. Dell Vostro 3450 System Board Replacement, Remove the System Fan: stap 46, afbeelding 1 van 1
    • Remove the system fan from the bottom base module.
  47. Dell Vostro 3450 System Board Replacement, Disconnect the DC-in Cable: stap 47, afbeelding 1 van 1
    • Disconnect the DC-in cable connector from the system board.
  48. Dell Vostro 3450 System Board Replacement, Disconnecting the Speaker Cable: stap 48, afbeelding 1 van 1
    • Disconnect the speaker cable from the system board.
  49. Dell Vostro 3450 System Board Replacement, Remove the Screws: stap 49, afbeelding 1 van 1
    • Remove the screws that secures the system board.
  50. Dell Vostro 3450 System Board Replacement, Disconnecting the System Board: stap 50, afbeelding 1 van 1
    • Disconnect the system board from the Input/Output panel.
  51. Dell Vostro 3450 System Board Replacement, Remove the System Board: stap 51, afbeelding 1 van 1
    • Lift and remove system board from the chassis.
Eindstreep
Johnathan Hammond
45.237 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 472
