Ga door naar hoofdinhoud
Dell Vostro 3360 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Vostro 3360 Hard Drive Replacement, Remove the Screw: stap 1, afbeelding 1 van 1
    • Remove the screw that secures the keyboard to the chassis.
  2. Dell Vostro 3360 Hard Drive Replacement, Prying the Keyboard: stap 2, afbeelding 1 van 1
    • Starting on the right side of the system, use a plastic scribe to pry up the keyboard from the computer.
  3. Dell Vostro 3360 Hard Drive Replacement, Flipping the Keyboard: stap 3, afbeelding 1 van 1
    • Flip the keyboard over and lay it on the palmrest.
  4. Dell Vostro 3360 Hard Drive Replacement, Lifting the Clip: stap 4, afbeelding 1 van 1
    • Lift the clip to release the keyboard cable and disconnect it from the computer.
  5. Dell Vostro 3360 Hard Drive Replacement, Remove the Screw: stap 5, afbeelding 1 van 1
    • Remove the screw that secures the access panel to the computer.
  6. Dell Vostro 3360 Hard Drive Replacement, Remove the Access Panel: stap 6, afbeelding 1 van 1
    • Remove the access panel from the computer.
  7. Dell Vostro 3360 Hard Drive Replacement, Display-Hinge Cover: stap 7, afbeelding 1 van 1
    • Remove the screws that secure the display-hinge cover to the computer
  8. Dell Vostro 3360 Hard Drive Replacement, Remove the Display Hinge Cover: stap 8, afbeelding 1 van 1
    • Remove the display-hinge cover from the computer.
  9. Dell Vostro 3360 Hard Drive Replacement, Prying the Rubber Pads: stap 9, afbeelding 1 van 1
    • Using a plastic scribe pry out the rubber pads that cover the front screws on the base cover.
  10. Dell Vostro 3360 Hard Drive Replacement, Remove the Screws: stap 10, afbeelding 1 van 1
    • Remove the screws that secure the palm-rest to the computer.
  11. Dell Vostro 3360 Hard Drive Replacement, Disconnecting the Board Cable: stap 11, afbeelding 1 van 1
    • Disconnect the quick launch board cable, the finger print reader cable, and the palmrest cable from the system board.
  12. Dell Vostro 3360 Hard Drive Replacement, Disconnecting the LED Cable: stap 12, afbeelding 1 van 1
    • Disconnect the power LED cable and the LED board cable from the system board.
  13. Dell Vostro 3360 Hard Drive Replacement, Remove the Screws: stap 13, afbeelding 1 van 1
    • Remove the screws that secure the palmrest to the front of the computer.
  14. Dell Vostro 3360 Hard Drive Replacement, Prying the Edges of the Palm-Rest: stap 14, afbeelding 1 van 1
    • Pry along the edges of the palmrest to release the palmrest.
  15. Dell Vostro 3360 Hard Drive Replacement, Lifting the Palm Rest: stap 15, afbeelding 1 van 1
    • Lift the palm-rest up and away from the computer.
  16. Dell Vostro 3360 Hard Drive Replacement, Hard Drive: stap 16, afbeelding 1 van 1
    • Remove the screws that secure the hard drive to the computer.
  17. Dell Vostro 3360 Hard Drive Replacement: stap 17, afbeelding 1 van 1
    • Lift the hard drive to disconnect the hard-drive cable
  18. Dell Vostro 3360 Hard Drive Replacement: stap 18, afbeelding 1 van 1
    • Disconnect the hard-drive cable from the hard drive and remove the hard drive from the computer
  19. Dell Vostro 3360 Hard Drive Replacement: stap 19, afbeelding 1 van 1
    • Remove the screws that secure the hard-drive bracket to the hard drive and remove the hard drive bracket from it.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Johnathan Hammond
45.237 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 3,355
