Ga door naar hoofdinhoud
Dell Vostro 1710 Heatsink Replacement
Wat je nodig hebt
  1. Dell Vostro 1710 Heatsink Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Vostro 1710 Heatsink Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 Heatsink Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 Heatsink Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery from the slot.
  4. Dell Vostro 1710 Heatsink Replacement, Back Panel: stap 4, afbeelding 1 van 2 Dell Vostro 1710 Heatsink Replacement, Back Panel: stap 4, afbeelding 2 van 2
    • Unscrew the eight 6mm screws with a Philips #1 screw driver.
  5. Dell Vostro 1710 Heatsink Replacement: stap 5, afbeelding 1 van 1
    • Lift back cover from the groove on the left side of the cover next to the symbol.
  6. Dell Vostro 1710 Heatsink Replacement, Fan: stap 6, afbeelding 1 van 2 Dell Vostro 1710 Heatsink Replacement, Fan: stap 6, afbeelding 2 van 2
    • Unclip the power supply by pulling the cable directly up and out of the socket.
  7. Dell Vostro 1710 Heatsink Replacement: stap 7, afbeelding 1 van 2 Dell Vostro 1710 Heatsink Replacement: stap 7, afbeelding 2 van 2
    • Remove the two 3mm screws located around the edge of the fan with a Philips #1 screw driver.
  8. Dell Vostro 1710 Heatsink Replacement: stap 8, afbeelding 1 van 2 Dell Vostro 1710 Heatsink Replacement: stap 8, afbeelding 2 van 2
    • Gently lift and pull to the left until the fan is free from the heatsink.
  9. Dell Vostro 1710 Heatsink Replacement, Heatsink: stap 9, afbeelding 1 van 2 Dell Vostro 1710 Heatsink Replacement, Heatsink: stap 9, afbeelding 2 van 2
    • Unscrew the four 8mm screws using a Phillips #1 screwdriver until the heatsink is free.
    • The screws do not come out, only loosen.
  10. Dell Vostro 1710 Heatsink Replacement: stap 10, afbeelding 1 van 2 Dell Vostro 1710 Heatsink Replacement: stap 10, afbeelding 2 van 2
    • Lift up on the heatsink to remove it from the laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tangxiao Sun
496 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S3-G7, Peak Spring 2018 Lid van UMass Dartmouth, Team S3-G7, Peak Spring 2018
UMASSD-PEAK-S18S3G7
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 285
