Wat je nodig hebt
Slide the battery lock to the open position.{2}
Slide the battery release latch to the open position. (You may need to hold the battery release latch in the open position while removing the battery.) {3}
Slide the battery out of the battery bay.{1}
Remove the two screws that secure the memory cover, then remove the cover and set it aside.
Één andere persoon heeft deze handleiding voltooid.
