Ga door naar hoofdinhoud
Dell Vostro 15 3568 Memory Module Replacement
Wat je nodig hebt
  1. Dell Vostro 15 3568 Memory Module Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the release latch to release the battery [1].
    • Remove the battery from the computer [2].
  2. Dell Vostro 15 3568 Memory Module Replacement, KeyBoard: stap 2, afbeelding 1 van 1
    • Release the keyboard by prying on the keyboard release tabs using a plastic scribe [1].
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [2].
  3. Dell Vostro 15 3568 Memory Module Replacement: stap 3, afbeelding 1 van 1
    • Disconnect the keyboard cable from the system board.
    • Lift the keyboard cable to remove it from the computer.
  4. Dell Vostro 15 3568 Memory Module Replacement, Base Cover: stap 4, afbeelding 1 van 1
    • Disconnect the optical drive connector and lift it to remove it from the system board [1].
    • Remove the screws inside the palmrest [2].
  5. Dell Vostro 15 3568 Memory Module Replacement: stap 5, afbeelding 1 van 1
    • Remove the screws that secure the base cover to the computer
  6. Dell Vostro 15 3568 Memory Module Replacement: stap 6, afbeelding 1 van 1
    • Pry the edges of the base cover [1].
    • Lift the base cover and remove it from the computer [2].
  7. Dell Vostro 15 3568 Memory Module Replacement, Memory Module: stap 7, afbeelding 1 van 1
    • Pull the clips securing the memory module until the memory module pops up [1].
    • Remove the memory module from the system board [2].
Conclusie
Johnathan Hammond
45.210 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 1,719
