Ga door naar hoofdinhoud
Dell Vostro 15 3565 Hard Drive Bracket Replacement
Wat je nodig hebt
  1. Dell Vostro 15 3565 Hard Drive Bracket Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the release latch to unlock the battery [1].
    • Remove the battery from the computer [2].
  2. Dell Vostro 15 3565 Hard Drive Bracket Replacement, Optical-Disk Drive: stap 2, afbeelding 1 van 1
    • Remove the screw that secures the optical drive to the computer [1].
    • Using a plastic scribe push the tab to release the optical drive [2].
    • Slide the optical drive out of the computer [3].
  3. Dell Vostro 15 3565 Hard Drive Bracket Replacement, KeyBoard: stap 3, afbeelding 1 van 1
    • Release the keyboard by prying on the keyboard release tabs by using a scribe.
  4. Dell Vostro 15 3565 Hard Drive Bracket Replacement: stap 4, afbeelding 1 van 1
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [1,2].
  5. Dell Vostro 15 3565 Hard Drive Bracket Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the keyboard cable from the system board [1].
    • Lift the keyboard cable to remove it from the computer [2].
  6. Dell Vostro 15 3565 Hard Drive Bracket Replacement, Base Cover: stap 6, afbeelding 1 van 1
    • Disconnect the optical drive connector and lift it to remove it from the system board [1,2]
    • Remove the screws inside the palmrest [3].
  7. Dell Vostro 15 3565 Hard Drive Bracket Replacement: stap 7, afbeelding 1 van 1
    • Remove the screws that secure the base cover to the computer [1].
    • Pry the edges of base cover and lift it to remove it from computer [2].
  8. Dell Vostro 15 3565 Hard Drive Bracket Replacement, Hard Drive: stap 8, afbeelding 1 van 1
    • Disconnect the hard drive cable from the connector on the system board [1, 2].
    • Remove the screws that secure the hard drive assembly to the computer [3].
    • Lift the hard drive assembly away from the computer [4].
  9. Dell Vostro 15 3565 Hard Drive Bracket Replacement, Hard Drive Bracket: stap 9, afbeelding 1 van 1
    • Pull the hard drive cable connector to remove it from the hard drive [1].
    • Remove the screws that secure the hard drive bracket to the hard drive [2].
    • Lift the hard drive from the hard drive bracket [3].
Conclusie
Johnathan Hammond
45.237 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 88
