Ga door naar hoofdinhoud
Dell Vostro 1400 Screen Replacement
Wat je nodig hebt
  1. Dell Vostro 1400 Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Be sure the power is off and all cables are unplugged from the device before starting.
    • After flipping over the laptop, the battery is on the bottom side of the laptop.
    • Find the tabs on both the left and right side of the battery.
  2. Dell Vostro 1400 Screen Replacement: stap 2, afbeelding 1 van 1
    • Push tabs toward the outside of the laptop until they lock in place.
  3. Dell Vostro 1400 Screen Replacement: stap 3, afbeelding 1 van 2 Dell Vostro 1400 Screen Replacement: stap 3, afbeelding 2 van 2
    • Push the battery forward to eject it from the laptop.
  4. Dell Vostro 1400 Screen Replacement, Screen: stap 4, afbeelding 1 van 1
    • Please make sure your device is completely turned off and everything is unplugged from the device
    • Open the laptop.
  5. Dell Vostro 1400 Screen Replacement: stap 5, afbeelding 1 van 2 Dell Vostro 1400 Screen Replacement: stap 5, afbeelding 2 van 2
    • Remove the 6 screw hole covers surrounding the screen.
    • Remove the 6 screws that were underneath the screw covers.
  6. Dell Vostro 1400 Screen Replacement: stap 6, afbeelding 1 van 2 Dell Vostro 1400 Screen Replacement: stap 6, afbeelding 2 van 2
    • Carefully remove the plastic surrounding the screen by pulling off, starting at the bottom.
    • Remove the two (2.5mm x 5mm) screws at the top, by the camera.
  7. Dell Vostro 1400 Screen Replacement: stap 7, afbeelding 1 van 2 Dell Vostro 1400 Screen Replacement: stap 7, afbeelding 2 van 2
    • Remove the two 5mm screws from the camera above the screen.
    • Remove the two 5mm screws from the bottom of the screen.
  8. Dell Vostro 1400 Screen Replacement: stap 8, afbeelding 1 van 2 Dell Vostro 1400 Screen Replacement: stap 8, afbeelding 2 van 2
    • Carefully remove the screen from the back cover.
  9. Dell Vostro 1400 Screen Replacement: stap 9, afbeelding 1 van 2 Dell Vostro 1400 Screen Replacement: stap 9, afbeelding 2 van 2
    • Lift up the black tag holding the camera and cable together.
    • Unplug the camera from the cable.
  10. Dell Vostro 1400 Screen Replacement: stap 10, afbeelding 1 van 3 Dell Vostro 1400 Screen Replacement: stap 10, afbeelding 2 van 3 Dell Vostro 1400 Screen Replacement: stap 10, afbeelding 3 van 3
    • Unplug the two cables connected to the screen.
  11. Dell Vostro 1400 Screen Replacement: stap 11, afbeelding 1 van 2 Dell Vostro 1400 Screen Replacement: stap 11, afbeelding 2 van 2
    • Remove the six 3mm screws on each side of the screen.
    • Remove the railing on each side of the screen.
    • The railing will be marked "L" for left side or "R" for the right. This should assist in reassembly.
Conclusie
David Hogg
727 Reputatie
5 handleidingen geschreven
Texas Tech, Team S8-G2, Bennett Spring 2017 Lid van Texas Tech, Team S8-G2, Bennett Spring 2017
TTU-BENNETT-S17S8G2
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 650
