Ga door naar hoofdinhoud
Dell Vostro 1400 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Vostro 1400 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Be sure the power is off and all cables are unplugged from the device before starting.
    • After flipping over the laptop, the battery is on the bottom side of the laptop.
    • Find the tabs on both the left and right side of the battery.
  2. Dell Vostro 1400 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Push tabs toward the outside of the laptop until they lock in place.
  3. Dell Vostro 1400 Hard Drive Replacement: stap 3, afbeelding 1 van 2 Dell Vostro 1400 Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Push the battery forward to eject it from the laptop.
  4. Dell Vostro 1400 Hard Drive Replacement, Hard Drive: stap 4, afbeelding 1 van 2 Dell Vostro 1400 Hard Drive Replacement, Hard Drive: stap 4, afbeelding 2 van 2
    • Please ensure that your device is turned off and everything is unplugged before working on it.
    • Unscrew both screws on the hard drive panel until the panel is able to be removed.
    • The screws will not come off of the panel.
    • Once screws have been loosened, remove the panel from the laptop.
  5. Dell Vostro 1400 Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • Remove the hard drive by pulling up on the black tab on the right side of the hard drive.
Conclusie
David Hogg
727 Reputatie
5 handleidingen geschreven
Texas Tech, Team S8-G2, Bennett Spring 2017 Lid van Texas Tech, Team S8-G2, Bennett Spring 2017
TTU-BENNETT-S17S8G2
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 720
