Ga door naar hoofdinhoud
Dell Vostro 1000 Memory Module Replacement
Wat je nodig hebt
  1. Dell Vostro 1000 Memory Module Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide and hold the battery-bay latch release on the bottom of the computer, and then lift the battery from the bay.
  2. Dell Vostro 1000 Memory Module Replacement, Memory Module: stap 2, afbeelding 1 van 1
    • loosen the captive screws on the memory module cover, and then remove the memory module cover.
  3. Dell Vostro 1000 Memory Module Replacement: stap 3, afbeelding 1 van 1
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • Use your fingertips to carefully spread apart the memory-module securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
Conclusie
Johnathan Hammond
45.615 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
44 Leden
1.996 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 290
