Ga door naar hoofdinhoud
Dell Venue 8 Rear Case/Midframe Replacement
Wat je nodig hebt
  1. Dell Venue 8 Rear Case/Midframe Replacement, Rear Case/Midframe: stap 1, afbeelding 1 van 1
    • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
    • You will hear click sounds as the clips unhinge
    • Remove the back panel of the device.
  2. Dell Venue 8 Rear Case/Midframe Replacement: stap 2, afbeelding 1 van 3 Dell Venue 8 Rear Case/Midframe Replacement: stap 2, afbeelding 2 van 3 Dell Venue 8 Rear Case/Midframe Replacement: stap 2, afbeelding 3 van 3
    • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
    • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
    • 4.45mm Silver screws
    • 3.6mm Black screws
    • Gently snap the perimeter clips open, and remove the internal plastic case.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Andrea
1.071 Reputatie
5 handleidingen geschreven
USF Tampa, Team 9-2, Leahy Winter 2015 Lid van USF Tampa, Team 9-2, Leahy Winter 2015
USFT-LEAHY-W15S9G2
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 2,434
