Inleiding
If your camera isnt functioning properly, not showing a display, or looks cracked or foggy, it may need to be replaced. In this guide we will be replacing the rear-facing camera.
Wat je nodig hebt
Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
Remove the back panel of the device.
Use the plastic opening tool to disconnect the camera from the logic board, by prying it up.
Één andere persoon heeft deze handleiding voltooid.
