Ga door naar hoofdinhoud
Dell Venue 8 7840 Screen Replacement
Wat je nodig hebt
  1. Dell Venue 8 7840 Screen Replacement, Screen: stap 1, afbeelding 1 van 1
    • Make sure your device is turned off. Leaving it turned on may cause an electric shock.
    • Face the device with the screen towards you.
  2. Dell Venue 8 7840 Screen Replacement: stap 2, afbeelding 1 van 1
    • With a plastic opening tool, pry open the bottom left corner of the screen.
    • The screen is tightly attached to the tablet, so you may have to use a metal spudger to pry it open if the plastic spudger does not do the task.
  3. Dell Venue 8 7840 Screen Replacement: stap 3, afbeelding 1 van 1
    • Next, pry open the top left corner of the screen.
  4. Dell Venue 8 7840 Screen Replacement: stap 4, afbeelding 1 van 1
    • Then, pry open the top right corner of the screen.
  5. Dell Venue 8 7840 Screen Replacement: stap 5, afbeelding 1 van 1
    • Lastly, pry open the bottom right corner of the screen.
  6. Dell Venue 8 7840 Screen Replacement: stap 6, afbeelding 1 van 1
    • Once you have pried open all the corners of the tablet, carefully open the screen from the right side of the tablet.
    • Do not try and open the screen from the left side of the tablet, because the screen is attached on the left side of the tablet; doing this can damage the tablet.
  7. Dell Venue 8 7840 Screen Replacement: stap 7, afbeelding 1 van 1
    • Once the tablet is opened, locate the connector.
  8. Dell Venue 8 7840 Screen Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the connector from the tablet.
Conclusie
Donnelle January
429 Reputatie
3 handleidingen geschreven
USF Tampa, Team 6-5, Remmell Fall 2016 Lid van USF Tampa, Team 6-5, Remmell Fall 2016
USFT-REMMELL-F16S6G5
3 Leden
6 handleidingen geschreven
3 opmerkingen
i wanted to replace the battery but dont know how to pry the screen open, is it attached with glue? thanks in advance.
dengzc - Antwoord
Where can I find a replacement screen for this device?
Karim Mohamed - Antwoord
Is the OLED connected with EDP 30=pin FPC?
Ron King - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 1,415
